Unicyclist Community
Reply
Old 2004-09-12, 01:48 AM   #1
Krashin'Kenny
Crash Tested
Krashin'Kenny's Avatar
Seat angle adjustment 101
After riding my homebuilt MUni frame for a little over a month, I've decided that I really like the feel of the Kris Holm saddle when the nose is tilted up. Here's how I acheived raising the nose of the saddle on my Coker. First, I took an old seatpost and cut a 3/16" groove about 2/3 of the way around it from the back. Next, I pressed down on the seatpost to close the gap and then welded the seam closed
__________________
If you ain't crashing, you ain't going fast enough!!!!!!!!!!!
Krashin'Kenny is offline   Reply With Quote
Old 2004-09-12, 01:49 AM   #2
Krashin'Kenny
Crash Tested
Here's a pic comparing a stock seatpost angle and the modified post
__________________
Old 2004-09-12, 01:51 AM   #3
Krashin'Kenny
Crash Tested
With the stock seatpost, the saddle was parallel to the handle. This is how the saddle now sets on the modified post
__________________
Old 2004-09-12, 10:41 PM   #4
andrew_carter
Back into muni!
andrew_carter's Avatar
Very clever, well done!
andrew_carter is offline   Reply With Quote
Old 2004-09-13, 10:53 PM   #5
Contender
Roman Allemann
Good job. I've actualy had that idea for a while but can't weld.
But that will all be fixed soon since I'm starting a welding class next week and buying a welder at some point.
Contender is offline   Reply With Quote
Reply
Tags
101, adjustment, angle, seat
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.05360 seconds with 11 queries
