Unicyclist Community
Reply
Old 2005-10-26, 04:27 PM   #1
kington99
Unicyclist
Send a message via MSN to kington99
Onza brake mounts
Having recently bought an '05 onza trials, I noticed the other day that the brake mounts don't appear to be in line with the rim edge, i presumed that it was designed to be used with Magura HS33s but i think if i fitted a pair they would only work on the tyre, which is no good. The lower of the two threaded bolt holes is about level with the rim, as far as i can remember the cylinder is equally placed between the two mounting holes on one of those brake cylinders, so it would miss by quite some way. Can anyone shed any light on this? Does it require different brakes, different mounting hardware, or have I somehow got a duff frame?
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2005-10-26, 06:49 PM   #2
pdc
Unicyclist
pdc's Avatar
Send a message via AIM to pdc
Yeah it's pretty much centered.
__________________
"What doesn't kill you strengthens you, what kills you strengthens your mother"
pdc is offline   Reply With Quote
Old 2005-10-26, 06:52 PM   #3
pdc
Unicyclist
pdc's Avatar
Another picture.
__________________
Old 2005-10-26, 08:15 PM   #4
kington99
Unicyclist
Cheers pdc, this is what mine looks like, anyone got any ideas?
__________________
Dave
Old 2005-10-26, 08:37 PM   #5
pdc
Unicyclist
pdc's Avatar
YIKES! I dont think there is a fix for that other than cutting off brazing on a new one and re powdercoating. Can you return/exchange it to the vendor?
Is that a 20" or a 24"?
__________________
Old 2005-10-26, 10:43 PM   #6
kington99
Unicyclist
It's a 20", I think it's going back to UDC, i just wanted to check on here first to make sure i wasn't being stupid. If mine's been incorrectly made then presumably there's a whole batch of them out there, check your Onzas people!
__________________
Dave
Old 2005-10-26, 11:06 PM   #7
Loosemoose
Coco... thanks guys.
Loosemoose's Avatar
Send a message via MSN to Loosemoose
Wow dave, I didn't even notice! Thats a very long way off, its too far up for even a 20" rim, so I can only assume that they used the 24" measurements or the 24" jig to locate the mounts, without realising that the frame was a 20". Return & replace the frame, Roger'll sort it out. Before you send it, make a measurement of bearing holder to mount distance, and we'll compare it to my onza 24" at christmas.
Loose.
__________________
Vice President - Southampton University Circus Society
"Come on you target for far away laughter,
come on you stranger, you legend, you martyr, and shine..." - Pink Floyd
Loosemoose is offline   Reply With Quote
Old 2005-10-26, 11:14 PM   #8
KcTheAcy
Ohh Baby
KcTheAcy's Avatar
Why do you want HS22's on a trials unicycle?
KcTheAcy is offline   Reply With Quote
Old 2005-10-27, 12:08 AM   #9
john_childs
Guinness Mojo
john_childs's Avatar
Quote:
I'll bet they measured the brake location for a 20" BMX wheel rather than the 19" trials wheel. A 19" trials rim is slightly smaller than a 20" BMX rim and that distance appears to be about the same as your brake mounts are off-center.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-10-27, 12:34 AM   #10
litldude2
Unicyclist
The mounts arent measured for a 24" frame, right now i am riding my trials with a 05 24"KH frame and the mounts are higher than that, the bottom one is even with the tire.
litldude2 is offline   Reply With Quote
Old 2005-10-27, 10:56 AM   #11
kington99
Unicyclist
Roger's reply to my email:
"The brake mounts on the Onza are a mystery for several reasons.
Firstly, As you can see they are not in the right place for the 19" rim,
they appear to be designed to fit a 20" rim if fitted. Secondly, they
were not specified with them at all because brakes are not used on
trials unicycles..."
Now i beg to differ on the subject of trials brakes, but as the advert on UDC's site does not imply in anyway that the Onza has brakes (either in the description or the photo) then I suppose I can't complain about the brakes that I have but which can't work.
For trials brake uses search, there was a thread a a few weeks ago.
__________________
Dave
Reply
Tags
brake, mounts, onza
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
20" Frame with Brake Mounts? e39m5 General Unicycling Discussions 7 2005-09-24 02:40 AM
second and third mounts phlegm General Unicycling Discussions 26 2004-12-02 09:12 AM
Mounts treepotato General Unicycling Discussions 7 2004-02-24 06:05 AM
Brake, no brake, uh, uh, no brakes Beener General Unicycling Discussions 14 2003-10-17 03:26 AM
Mounts? Nycjoe General Unicycling Discussions 18 2002-01-28 06:54 PM
Powered by vBulletin®
Copyright © 2001-2019 Gilby
Page generated in 0.10255 seconds with 12 queries
